Printing to close to the bed in one particular spot
wless1
(@wless1)
Hi all,
I've had my MK3 for a while now and it's typically printed great. After not using it for a while and coming back to it, I started to experience a problem. It's very obvious when the printer is making the skirt around my print that, in a particular area, it's printing too close to the bed:
It completes XYZ calibration with minimal skew, and belt tension seems okay. Can anyone help me diagnose the problem?
Thanks!
Veröffentlicht : 21/06/2018 7:01 am
RH_Dreambox
(@rh_dreambox)
Re: Printing to close to the bed in one particular spot
Maybe a bit of filament debris under the steel sheet?
Veröffentlicht : 21/06/2018 8:59 am
Gato
 Gato
(@gato)
Maybe 2 factors at play. 1) live z is too low and 2) bed is not leveled.
I would recommend checking bed level first using Ocotprint plugin for bed visualizer (posted in this forum). Once bed is leveled, perform extruder multiplier calibration and then perform live z by following the (live z my way posted on this forum).
Veröffentlicht : 21/06/2018 6:28 pm
wless1
(@wless1)
Thanks! Is this the octoprint plugin for visualizing the bed: https://github.com/PrusaOwners/OctoPrint-PrusaMeshMap ?
Also, how do I do extruder multiplier calibration?
Veröffentlicht : 21/06/2018 7:42 pm
Gato
 Gato
(@gato)
Yep, that’s the one. For Extruder multiplier calibration see second calibration described here: https://www.google.com/amp/s/mattshub.com/2017/04/19/extruder-calibration/amp/
Good luck
Gaston
Veröffentlicht : 21/06/2018 9:07 pm
