Print shifting
mordechai.s
(@mordechai-s)
Print shifting
Can anyone help me with this. It seems that the prints are shifting to the left. See attachment for an example.
Postato : 14/09/2018 7:16 pm
LaPointe
(@lapointe)
French moderator and translator Moderator
Re: Print shifting
Is it a kit built MK3?
Have you already succeeded to print other objects, including the ones that come with the printer on the SD card?
What are the values of the belt status?
Postato : 15/09/2018 12:19 pm
Olef
 Olef
(@olef)
Re: Print shifting
Either your X axis belt tension is too high, or your X axis motor pulley is moving on the motor shaft. Check the pulley grubscrews for tightness.
Postato : 18/09/2018 7:55 am
