[Rozwiązany] Power supply does not turn on.
Zappovitz
(@zappovitz)
Hi.
I have just finished assemblying the i3 Mk3s kit.
When I turn on power nothing happens.
Am I correct in assuming that the power switch should light up? It looks like a power switch with light in it.
What can I do to figure out if the power supply is defect?
Regards
Christian Zacho Hansen
Opublikowany : 29/04/2020 1:46 am
Zappovitz
(@zappovitz)
RE: Power supply does not turn on.
Have testet the fuse  .. continuity is ok
No light in Green LED
Measured Vout on 1 and 2 ... no 24v
Opublikowany : 29/04/2020 2:49 am
RH_Dreambox
(@rh_dreambox)
Some have had problems when they have not pressed the power cord plug properly. So check if you can push it a little further.
Opublikowany : 01/05/2020 7:49 am
rmm200
(@rmm200)
Plug has to enter the PSU socket a good .5". Use more force than you think appropriate, and do it on a flat surface in front of you.
Not trying to reach the back of an enclosure, like I did.
Opublikowany : 02/05/2020 10:26 pm
Zappovitz
(@zappovitz)
Did talk to support .. they sent me a new powersupply .. should be here Monday ...
Opublikowany : 02/05/2020 11:56 pm
