Poor Surface Finish
Solidev
(@solidev)
Poor Surface Finish
Has anyone had an issue with these types of artifacts in the surface finish?
Filament is not dragging. The X/Y axes are moving smoothly. Unable to influence with flow rate adjustments.
Printer is a brand new, factory assembled MK3S+
Surface Finish X-Axis:
Surface Finish Y-Axis:
Top surface, 6 layers, 30% infill:
Printer right next to it, smooth finish:
Best Answer by Solidev:
The issue was due to vibration from another printer. I moved to another table and it cleaned up. Silk shows everything man.
Postato : 18/12/2022 6:07 pm
Magig_I3Prusa
(@magig_i3prusa)
RE: Poor Surface Finish
seams the overlap is 0,01 to mutch so it stands out
but it is real good what are yoiu expecting on a FDM
there will not be a polished surface
Postato : 18/12/2022 6:22 pm
Solidev
(@solidev)
Fist layer not continuous lines. Dotted.
Postato : 18/12/2022 6:27 pm
Solidev
(@solidev)
Posted by: @magig_i3prusa
I'm expecting the same results I see on my other printers...
Postato : 18/12/2022 6:31 pm
Solidev
(@solidev)
Postato : 19/12/2022 1:44 am
2 persone hanno apprezzato
