Poor Surface Finish
Has anyone had an issue with these types of artifacts in the surface finish?
Filament is not dragging. The X/Y axes are moving smoothly. Unable to influence with flow rate adjustments.
Printer is a brand new, factory assembled MK3S+
Surface Finish X-Axis:
Surface Finish Y-Axis:
Top surface, 6 layers, 30% infill:
Printer right next to it, smooth finish:
Best Answer by Solidev:
The issue was due to vibration from another printer. I moved to another table and it cleaned up. Silk shows everything man.
RE: Poor Surface Finish
seams the overlap is 0,01 to mutch so it stands out
but it is real good what are yoiu expecting on a FDM
there will not be a polished surface
I'm expecting the same results I see on my other printers...
