PLA - supports print problem
Martin Foldyna
(@martin-foldyna)
Hello,
I spent lot of time on internet trying to find, why I have always problem to print something with using supports. In the example below I'm using PLA from Creality. Printing at 215°C with extrusion multiplier to 0,9 (I was thinking that the problem is with over extrusion).
Can you help me with your opinions? Thank you
I
Posted : 07/10/2022 11:07 am
jsw
 jsw
(@jsw)
My guess is that the settings are well within tolerance.
Yes, there can be an issue of the very tiny 'square wave' sections of break-away support footings curling up and failing to adhere and it can be very frustrating.  I've found that more often than not it happens with PLA filaments.
I have found that an adhesion booster really helps out in this case.  I prefer Layerneer, but there are others such as Magigoo, or even glue stick.  Some even use hair spray or dilute glue solutions.
I wrote a review of this product a couple of years ago and I swear by it in cases like this.
Posted : 07/10/2022 11:14 am
As far as I can see from the pictures, the Z-Adjust seems to be not optimal (too high). Try to go a little lower step by step (0.05mm).
wbr,
Karl
Posted : 07/10/2022 12:14 pm
