PLA printing issues possibly under extrusion?
Arlin
(@arlin)
Hi all,
I'm running into some pretty frustrating issues printing with PLA which I think these are under extrusion issues. Any thought on the cause of this - I'm not sure where to go from here.
Fixes tried:
https://help.prusa3d.com/article/under-extrusion_2007
- Changing temp +/-
- Cleaning nozzle
- Checking extruder gear alignment on shaft
- Tightening idler screw/ spring
- Cold pulls
- Centered extruder gear and ensure grub screw was tightened
- Experimental menu for heat creep (  https://help.prusa3d.com/article/experimental-menu-mk3-s-_161213)
Picture of the first layer:
Previous Post: https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/new-mk3s-extruder-thumping-and-under-extrusion/#post-634282
Posted : 10/04/2023 8:32 pm
NickAtNight
(@nickatnight)
RE: PLA printing issues possibly under extrusion?
You only posted a first layer?   Are you sure your live Z is set correctly?
Please find a better extrusion test print and post results.
Underextrusion.
Posted : 10/04/2023 9:21 pm
