Pinda connector with 3 pins instead of 4
Hi everybody,
I have a problem assembling the mk3. In the elektroinstalation I noticed that my PINDA cable has 3 pins, but on the board for a 4 pin stacker is provided. Is this now a wrong, newer or older PINDA probe? A connection with the 3 pin plug is unfortunately not possible.
Does anyone have the same problem? And how was / is the solution?
Thanks in advance
Mathias
Re: Pinda connector with 3 pins instead of 4
Chat to support Mathias from the shop page, they will sort you out.
From the comments on the online build manual
https://manual.prusa3d.com/Guide/8.+Electronics+assembly/513?lang=en
Hello everybody,
Thank you for the answers. I wrote an email to [email protected] ...
I will tell you about the solution.
greetings
Mathias
you can use the online chat on there shop webage for a quicker response
