Pinda connector with 3 pins instead of 4
mathias.v3
(@mathias-v3)
Hi everybody,
I have a problem assembling the mk3. In the elektroinstalation I noticed that my PINDA cable has 3 pins, but on the board for a 4 pin stacker is provided. Is this now a wrong, newer or older PINDA probe? A connection with the 3 pin plug is unfortunately not possible.
Does anyone have the same problem? And how was / is the solution?
Thanks in advance
Mathias
Opublikowany : 09/09/2018 10:31 am
Olef
 Olef
(@olef)
Re: Pinda connector with 3 pins instead of 4
Chat to support Mathias from the shop page, they will sort you out.
Opublikowany : 09/09/2018 1:28 pm
Robin
(@robin-4)
From the comments on the online build manual
https://manual.prusa3d.com/Guide/8.+Electronics+assembly/513?lang=en
Opublikowany : 09/09/2018 2:24 pm
mathias.v3
(@mathias-v3)
Hello everybody,
Thank you for the answers. I wrote an email to [email protected] ...
I will tell you about the solution.
greetings
Mathias
Opublikowany : 09/09/2018 2:57 pm
Robin
(@robin-4)
you can use the online chat on there shop webage for a quicker response
Opublikowany : 09/09/2018 3:15 pm
