PINDA adjustment
Jerry S
(@jerry-s)
PINDA adjustment
Just replaced extruder parts because of a melt down. All new parts but the PINDA position definitely looks wrong. Is it a bad part or is it OK?
Napsal : 17/01/2021 5:03 pm
RE: PINDA adjustment
Posted by: @jerry-s
It seems that the PINDA holder on the extruder was bent during your "melt down" accident. Maybe you can straighten this area with a hot air gun with a lot of care, because the sensor does not switch exactly in the angled position. In the worst case, the extruder part must be reprinted.
Napsal : 17/01/2021 6:27 pm
@karl-herbert
Or just replace it.  I have had a couple go wonky with heat.  I would print another one in ABS or PC Blend.
Napsal : 18/01/2021 4:06 am
