Only one z-axis motor works
robotdad
(@robotdad)
Hi, just finished assembly of my i3 Mk3 and am having some trouble with the z-axis. In running through the calibration only the left z-axis motor was running so it failed. I checked the connections and swapped the connection for the left and right z-axis motors. Running calibration again now the right z-axis motor runs and the left one does not. What should I check?
Opublikowany : 25/06/2018 8:07 am
Martin Wolfe
(@martin-wolfe)
Re: Only one z-axis motor works
Contact Prusa support via online chat and have a Video of the Z motor not working in both positions to hand. It sound like you have a defective Einsy board.
Regards,
Martin
Martin Wolfe
Opublikowany : 25/06/2018 9:41 am
robotdad
(@robotdad)
I heard from Prusa support and they confirmed it sounds like a bad Rambo board and have a replacement on the way to me now.
Opublikowany : 27/06/2018 6:03 pm
robotdad
(@robotdad)
Final update on this. I am an idiot. I had one of the Z motors and the E motor swapped. I don't know how I determined to wire it that way as the manual is quite clear on how this should be wired. I'm a further nit wit in that I kept wiring it that way without double checking the diagrams. I should have posted a pic of how I hooked up the wires from the start, as soon as support saw what I did they corrected me. At least I now know why no one else ever ran into this... It's bloody hard to screw up this bad.
Opublikowany : 04/07/2018 9:42 am
asmund.h
(@asmund-h)
Well, you are not the only one. Exact same thing happened to me.
Opublikowany : 06/07/2018 10:38 pm
asmund.h
(@asmund-h)
asmund.h
(@asmund-h)
JMAC
 JMAC
(@jmac)
Don’t beat yourself over that! I, for one, tried to run my pre-built MK2S on 220 volts here in the US, without any success. After this was brought to my attention by support I switched the power supply and all was OK. Of course, I had not read the Handbook - lesson learned!
I have since built kit versions with no problems...so easy to miss the obvious. :mrgreen: :mrgreen: :mrgreen:
Opublikowany : 07/07/2018 1:46 am
