Old STL file needed
Gavin Melville
(@gavin-melville)
Old STL file needed
I'm repairing a MK3S and need a extruder body.  The original was marked R4, the only file I can find on GITHUB (same as the part in the shop)  is somewhat different and marked R6.  Does anyone know if it is compatible ?
Kind Regards,
Gavin
Opublikowany : 01/08/2025 8:26 pm
You are looking for an early part.  Most of the early collections were uploaded to Printables in 2021 but apparently the R4 set wasn't ...
https://www.printables.com/@Prusa3D/collections/54487
Your best course is to contact Prusa Support via Chat.  They will know where to download something that will fit.
Opublikowany : 02/08/2025 7:02 am
RE: Old STL file needed
The R4 was in the MK3 to Mk3s upgrade files originally iirc.
Opublikowany : 02/08/2025 8:26 am
