Odd Print Artifacts
joelclarkdev
(@joelclarkdev)
Odd Print Artifacts
I am getting some weird printing artifacts on the first layer.  The photo doesn't really do it justice, but this is the best I have taken so far.  Any ideas?
Best Answer by JoanTabb:
Hi Jsc,
are you using 7x7 mesh  bed levelling?
available on the LCD Menu!
Publié : 30/01/2020 4:57 am
Lichtjaeger
(@lichtjaeger)
RE: Odd Print Artifacts
The nozzle is too close to the bed. You need to readjust your Z calibration.
Publié : 30/01/2020 6:45 am
joelclarkdev
(@joelclarkdev)
@lichtjaeger
Hi, thanks for the quick reply.  I backed off my squish and changed to a non-translucent filament.  Here is the bottom of a new print with my altered settings.  I used to see the texture of the steel bed but now I see the nozzle paths.  Did I back it off too far you think?  I am not 100% what the bottom should look like to be honest.  Thanks again for the assist.
Publié : 30/01/2020 5:19 pm
Hi JSC,
If the test patch peels off as a single foil, the Live Z is about right, if it peels off as strings you are a tiny bit too high...
Publié : 30/01/2020 6:00 pm
joelclarkdev
(@joelclarkdev)
@joantabb
Ok that is great to know, thank you.  Now, I did that single layer test again and half the square separates and half doesn't.  Not sure what the level tolerances are for the print bed, but I did not expect that outcome.  I think this explains why I only saw the original artifacts on part of the piece and not all of it.
So, I could squish just a tad more but I am concerned that have a bed leveling issue.  Maybe do the wizard again?  Could this be an assembly issue?
Publié : 30/01/2020 8:00 pm
Hi Jsc,
Publié : 30/01/2020 8:29 pm
joelclarkdev
(@joelclarkdev)
@joantabb
You are amazing!!!  That seems to give me a very consistent first layer.  Thanks!
--Joel
Publié : 30/01/2020 9:02 pm
@jsc-7b7
Cheers Joe, Glad to help!
Joan
Publié : 30/01/2020 9:03 pm
GKMAKEIT
(@gkmakeit)
@jsc-7b7
Here's an example of a good first layer at 0.200mm, PETG. First picture is the hot end side and the second build plate side. If you want a PLA example let me know.
Publié : 31/01/2020 3:16 am
