Odd Print Artifacts
I am getting some weird printing artifacts on the first layer. The photo doesn't really do it justice, but this is the best I have taken so far. Any ideas?
Best Answer by JoanTabb:
Hi Jsc,
are you using 7x7 mesh bed levelling?
available on the LCD Menu!
RE: Odd Print Artifacts
The nozzle is too close to the bed. You need to readjust your Z calibration.
@lichtjaeger
Hi, thanks for the quick reply. I backed off my squish and changed to a non-translucent filament. Here is the bottom of a new print with my altered settings. I used to see the texture of the steel bed but now I see the nozzle paths. Did I back it off too far you think? I am not 100% what the bottom should look like to be honest. Thanks again for the assist.
Hi JSC,
If the test patch peels off as a single foil, the Live Z is about right, if it peels off as strings you are a tiny bit too high...
@joantabb
Ok that is great to know, thank you. Now, I did that single layer test again and half the square separates and half doesn't. Not sure what the level tolerances are for the print bed, but I did not expect that outcome. I think this explains why I only saw the original artifacts on part of the piece and not all of it.
So, I could squish just a tad more but I am concerned that have a bed leveling issue. Maybe do the wizard again? Could this be an assembly issue?
Hi Jsc,
@joantabb
You are amazing!!! That seems to give me a very consistent first layer. Thanks!
--Joel
@jsc-7b7
Cheers Joe, Glad to help!
Joan
