Odd Bubbling on Outside of print
ichibanson
(@ichibanson)
Hello!
I seem to be getting some bubbling around the outside of a first layer print. I'm trying to dial in my Z axis but keep getting this same pattern on multiple prints. I've tried recalibrating all axis, using different filaments, temps, cleaning the bed with 70% IPA but no luck...
Gray print is bent since I pulled it off right after the print finished.
Any ideas?
Respondido : 05/12/2021 1:25 am
ichibanson
(@ichibanson)
Extruder is making noise, not sure if this sounds normal or not. Towards the end of the clip there's a very slight ticking.
https://drive.google.com/file/d/1BSii4ZprJF11lT_vyFjSx_H8KUPWVKTx/view?usp=sharing
Respondido : 05/12/2021 1:50 am
ichibanson
(@ichibanson)
RE: Odd Bubbling on Outside of print
Reloaded new Gcode from the same .stl and got this. Still some imperfections, is the requirement to use 90% IPA or higher? Looks like fingerprints on the back.
Respondido : 05/12/2021 2:31 am
I wash my buildplate, rinse and dry immediately, using plain paper towels.
Regards Joan
Respondido : 05/12/2021 8:26 am
sylviatrilling
(@sylviatrilling)
Try washing the sheet with dishwashing detergent.
Mk3S+,SL1S
Respondido : 05/12/2021 1:08 pm
Your first layer Z calibration is fractionally too low, too much squish, and the excess material is bulging out at the sides causing ripples in the sheet.
And I second the remarks about cleaning with detergent and HOT water.
Respondido : 05/12/2021 2:55 pm
