Nuzzle touch my print
meruem.sama
(@meruem-sama)
Hello,I'm french so sorry for my bad english ;D
I have a problem, at the end of my assembly, everything works impeccable, I managed to print the benchy
but when I made the print a little more complicated like the vase proposed by Prusa, or another print that I wanted to do: the nozzle does that touch and move the impression, I try to move the probe PINDA and to do the calibration first layer but I can not, always the same result ...
Thanks you For your help 😀
Opublikowany : 13/07/2019 2:55 pm
RE: Nuzzle touch my print
If this is a PLA model, Make sure that your build plate is impecably clean. And consider reducing the extrusion multiplier  to 0.95
To reduce the chances of over extrusion
Regards  Joan
Opublikowany : 13/07/2019 7:02 pm
