Ninjatek Cheetah Settings for PrusaSlicer
davisjc22
(@davisjc22)
Does anybody have settings recommendations for printing Cheetah on the Mk3S? The following is from Ninjatek's website, but I'm wondering if anybody has found that something else works better.
Extruder Temperature:  230°C – 240°C
Platform Temperature:Room temperature – 40°C
Glue or blue painters tape is suggested if not using a heated bed.
Print Speed:
Top and bottom layers:30-45 mm/ sec (1800-2700 mm/ min)
Infill speeds: 60-80 mm/ sec (3600-4800 mm/ min)
Layer 2+ use cooling fan if available.
Publié : 31/05/2019 5:18 pm
marcusone
(@marcusone)
any updates
Did you ever get an answer to this or figure it out?  Thank you.
Posted by: @john-d45
Print Speed:
Did you find a solution to this/how has your printing with this TPU gone?
Thank you.
Publié : 09/10/2021 12:48 pm
Dangc10
(@dangc10)
Succesful test in 2021
I tried with the Saintsmart TPU setting from current prusaslicer (2.3.3) , since its has the same shore hardness (95) it worked quite well!
Publié : 03/11/2021 8:36 pm
