New user trying to set up
brian.p22
(@brian-p22)
I run self test and get filament sensor wire error, check connections all good yet it fails every try. and ideas what to check other than wire connections?
Napsal : 24/07/2018 6:51 pm
RufusClupea
(@rufusclupea)
Re: New user trying to set up
The wire itself? It's possible there's a kink/break somewhere inside the insulation. Look for a bend or other deformation. Some kind of circuit tester may help determine if it's the wire or something else.
That's "MISTER Old Fart" to you!
Napsal : 24/07/2018 6:57 pm
Pathogen
(@pathogen)
My filament sensor would never be recognized until I left the printer powered ON and then pulled the connector and reinserted it.
Napsal : 27/07/2018 10:14 am
