New nozzle - First Layer not working
earthor
(@earthor)
I've sized up to 0.8 nozzle now my prints are not working. Note: I have set my HW settings to reflect a 0.8 nozzle.
Issue #1 : Stringing - This doesn't seem to be a z-axis issue. Even after the print is done it still oozes material and strings across the bed.
Issue #2: Consistency / sticking? It's either not sticking at all, or its basically rubbing the nozzle against the plate. I can't find a sweet spot. It will run a nice straight line, then randomly break. \
Below are two first-layer tests with the exact same z-axis settings..
Looking for suggestions, thanks!
Publié : 06/07/2022 8:34 pm
The usual advice about a really clean print-sheet applies but 0.8mm is pushing the max for the hotend.  Try reducing speed by 10% or increasing the print temperature by a few degrees.
Publié : 07/07/2022 12:40 am
Membre
RE: New nozzle - First Layer not working
You may also have a wet filament.  What you tried to dry it?  Do you hear any popping when it is heated up?
Publié : 07/07/2022 10:54 am
Robin
(@robin)
The build in first layer calibration is for use with a 0.4 nozzle only. You need to slice your own calibration print for other diameters.
See: https://help.prusa3d.com/article/different-nozzle-types_2193#first-layer-calibration-of-other-nozzles
Publié : 07/07/2022 11:39 am
