New Assembly, Unable to Connect via Pronterface
C. O.
(@c-o)
Hey everyone,
I have a newly assembled MK3s here. Successfully calibrated and flashed firmware, however when I try to connect to the printer via Pronterface, I get the following error.
Connecting...
start
Printer is now online.
echo: 3.7.0-2201
echo: Last Updated: Apr 1 2019 20:55:37 | Author: (none, default config)
Compiled: Apr 1 2019
echo: Free Memory: 2073 PlannerBufferBytes: 1392
echo:Hardcoded Default Settings Loaded
adc_init
CrashDetect ENABLED!
FSensor ENABLED
echo:SD card ok
echo:Unknown command: "105"(2)
Thanks!
Opublikowany : 07/04/2019 2:16 am
Mustrum Ridcully
(@mustrum-ridcully-2)
Re: New Assembly, Unable to Connect via Pronterface
what computer? Windows 10 pro, or Mac OSx 10.4.x, or linux?
Can you print from the provided SD card with the provided gcode files?
Prusa do not monitor these forums this is user to user support
contact prusa online chat system 24/7 support
log into your account on one of the prusa store pages and in the bottom right corner you will see the Chat system box click in it enter your Invoice number for you Prusa and start the chat system they do an excellent job and will take good care of you.
Opublikowany : 07/04/2019 5:07 am
