Move Z < 1 mm
sam.b
(@sam-b_1551625867)
Move Z < 1 mm
I'm trying to check my PINDA sensor level. and have printed off this test tool to compare the PINDA height to the intended height:
https://www.thingiverse.com/thing:1977997
The problem I'm running into:
When I try to adjust Z down (Using Settings->Move Axis->Move Z), it moves in steps of whole millimeters.
I need it to move in sub-millimeter steps to get this probe under the sensor: At 3.1 mm off the bed, neither the nozzle nor the PINDA sensor is near the calibration probe. At 2.1mm, they're both crushing into it. I need to get the Z height to something like 2.7mm to see which one touches the calibration probe first.
How do I move the Z axis in smaller steps than a single mm?
(Image of attempted calibration attached)
Opublikowany : 11/05/2018 8:57 pm
reid.b
(@reid-b)
Re: Move Z < 1 mm
Settings -> Live adjust Z - then spin knob...
Note, after doing the above, set Live adjust Z back to zero before doing a Calibrate XYZ.
Opublikowany : 11/05/2018 9:15 pm
sam.b
(@sam-b_1551625867)
Re: Move Z < 1 mm
Thanks. This does indeed confirm my PINDA sensor is lower than it ought to be in relation to the nozzle.
Opublikowany : 11/05/2018 11:27 pm
