MK3S Y-Axis Length Error, Overrunning
mjmurray
(@mjmurray)
I had a short circuit on my Einsy and I replaced it. Since then, I have had an issue with the y-axis. When I manually move the bed (by hand) with the printer turned off, I am able to easily slide it from end to end. I was able to calibrate the X/Y/Z successfully, but I ended up needing to replace the nozzle, and since then, I have had issues with the Y. I was able to run the first layer calibration, but when I tried to print a Benchy, the layers were all over the place in terms of the Y (literally seemed to be random and off by easily 10cm). Now the z/y/z calibration is failing, as is the belt test in the Y. Usually, when I calibrate or home it, the Y runs to the hard stop, moves, runs back into the hard stop, then it's zeroed. NOW however, it seems like the motor is trying to run it past the end. The motor is clearly still running when it's reached the hard stop. It's not grinding or anything though. No idea what this means, but to me it implies that the expected Y axis length is longer than it should be. I redownloaded and flashed the firmware again to make sure I have it correct. It's the latest, prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex.
Best Answer by Chicago Keri:
Is the motor pulley setscrew tight? Perhaps the motor shaft is spinning within the pulley.  The motor should be easily stopped when the end of travel is reached even if the belt is fairly loose.
Respondido : 27/02/2022 5:05 pm
mjmurray
(@mjmurray)
RE: MK3S Y-Axis Length Error, Overrunning
It looks like the y motor is still able to turn once it's reached the end, I tried both loosening and tightening the belt to no avail.
Respondido : 27/02/2022 6:10 pm
Chicago Keri
(@chicago-keri)
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говорю по-русски но не очень хорошо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Respondido : 01/03/2022 2:30 am
mjmurray
(@mjmurray)
yep, i had actually just done that and it worked. Thanks!
Respondido : 01/03/2022 2:51 am
