MK3S X Issue
Hawaha
(@hawaha)
MK3S X Issue
So I have been printing fine since I have gotten this printer towards the end of 2019.   I have ran into an issue today.  My X is forgetting where home is.
I have restarted the calibration wizard and it looks like the Y or the X skips all of a sudden causing the X to be off and crash the system.  When it goes to auto level and start a print it doesn't set the X back to the front Left it just starts it where it is.   I now have three pressure points in my Build plate because the sensor failed to stop and it auto stopped before doing more damage.  This hasnt happened to me before and I have over 700 hours on this printer printed.
Has anyone had this issue where it just forgets how to home?
Opublikowany : 11/04/2020 7:47 pm
1 ludzie polubili
RE: MK3S X Issue
When was the last time you cleaned and lubed the Smooth Rods?
The bearings are likely to jam if left dry!
Opublikowany : 11/04/2020 8:13 pm
Hawaha
(@hawaha)
RE: MK3S X Issue
@joantabb
That most likely the issue after poking around the interwebs.   I have the tub of lubrication that came with the kit and Im getting some WD-40 lithium grease for other stuff.
Opublikowany : 13/04/2020 3:16 pm
RE: MK3S X Issue
Good luck
Opublikowany : 13/04/2020 3:36 pm
