MK3S Upgrade Stringing
So after doing my upgrade to MK3S I'm now getting serious stringing.
E.g. https://photos.app.goo.gl/fFLA6xhpLhSunboJ9
I wasn't getting any stringing at all before I did the upgrade, using the same filament.
Things I've tried so far:
* Checked the hot end fan is working
* Changing the Retraction Length (all the way up to 2mm)
* Changing the Lift Z (also all the way up to 2mm)
* Changing the filament temperature (all the way down to 190°C)
Nothing seems to have any effect so far. Is there anything else I should be trying? Is there anything I've likely done wrong in my upgrade that'd be causing this?
Napsal : 01/03/2020 11:20 pm
Ty se líbí
