MK3S+ printing fan not working - cannot complete first layer calibration
admpc
(@admpc)
Hi everyone, I have a MK3S+, I managed to get some (like 3 or 4) prints and then I had a bad clog. I changed ptfe tube and cleaned up the bondtechs, other than that everything looked fine. Now i'm not able to finish the first layer leveling test: the printing fan does not start and the filament does not stick to the bed but adds up on the nozzle till it clogs (actually I stop before that happens). I tried with bot pla and petg, but the "front fan" does not start at all during this (while I don't recall if it did before). So I think the problem is this, but from the menu i can get that fan to spin, so it is not an electrical problem.. I just flashed last firmware 3.9.3 and tried again, but the problem remains.
Any suggestions??
Posted : 08/05/2021 9:13 am
RE: MK3S+ printing fan not working - cannot complete first layer calibration
For standard pla profiles the part fan is not usually turned on until the second layer, for petg profiles its off for the first 3 layers normally.
Not sticking to the bed is down to either first layer z height adjustment or bed cleanliness.  There are 1001 threads on here about how to correctly clean your print sheet and adjust the first layer correctly.
Posted : 08/05/2021 9:21 am
Clarmrrsn
(@clarmrrsn)
Pg1 then pg40 for Joans Pictures.
Should be made to read this thread on joining. 😁  not all 40 pages mind you
Tank you very much!
Posted : 08/05/2021 9:26 am
