MK3S Overhang finish rough on both top and bottom
ben.b12
(@ben-b12)
I have been trying to find out whats going on with my print and having no luck I have just assembled my new I3 MK3S. The first thing I printed was the whistle as that came out perfect nice and smooth, I then tried to print a small bowl and set it to use supports for some reason about 5 layers up it went all rough the supports are smooth like the whistle. I used prusa control 0.9.4_415_beta to slice the model.
I have checked all the belts and they seem right smooth movement on X / Y and Z axis, I don't know if it's the extruder pusing to much out but I find it strange that I printed these two objects one after the other whistle first then bowl no changes of settings and the bowl has that rough finish. Could this just be a slicer issue or is there something not quite right with my machine.
Publié : 04/03/2019 10:23 pm
gnat
 gnat
(@gnat)
Re: MK3S Overhang finish rough on both top and bottom
What does the top and bottom (as printed) of the whistle look like?
What I see looking at the bowl is that you need to adjust your Live Z. The lines are way too visible in the bottom. A bad Live Z can also cause the rest of what you are seeing too.
If you haven't already, dig up the "life z adjust" thread (sorry I never have it handy) as that provides a much better test than the built in calibration.
MMU tips and troubleshooting
Publié : 04/03/2019 11:39 pm
ben.b12
(@ben-b12)
Ok thanks here is a picture of the top and bottom of the whistle, and is this the thread you mean https://shop.prusa3d.com/forum/assembly-and-first-prints-troubleshooting-f62/life-adjust-z-my-way-t2981.html
Publié : 05/03/2019 12:58 am
gnat
 gnat
(@gnat)
The whistle doesn't looks as bad, but it looks like there is still a bit of room for adjustment.
Yes that is the thread.
Publié : 05/03/2019 2:34 am
ben.b12
(@ben-b12)
Thanks for pointing me in the right direction looks like that was the issue printing much better now but still some small tweaks to the live Z needed I think.
Publié : 05/03/2019 11:08 pm
gnat
 gnat
(@gnat)
Glad I could help.
Publié : 06/03/2019 6:21 am
