Mk3s+ kit ptfe
giodee
(@giodee)
Mk3s+ kit ptfe
is the ptfe tube pre-installed on the hot end in the kit?
Opublikowany : 23/08/2022 1:00 am
RandyM9
(@randym9)
RE: Mk3s+ kit ptfe
Yes. Was that a redaction?
Opublikowany : 23/08/2022 3:41 am
giodee
(@giodee)
RE: Mk3s+ kit ptfe
Thank you very much.  I've completed my build, but was considering taking apart extruder/ hotend because I didn't put in the tube. That's a relief.
I didn't put the lines through my original post intentionally.
Opublikowany : 23/08/2022 4:06 am
RE: Mk3s+ kit ptfe
The forum randomly selects strikeout... Or so it seems.
Joan
Opublikowany : 23/08/2022 7:44 am
RandyM9
(@randym9)
RE: Mk3s+ kit ptfe
Okay, good. I wasn’t sure if you’d already found the answer and gone back to edit your post (although the forums give you precious little time to do so).
At any rate, the hotend in the MKS3+ Kit arrives fully assembled from Prusa.
Enjoy your new printer!
Opublikowany : 24/08/2022 4:06 am
