MK3S+ kit autoloading fail
stellr
(@stellr)
Turned on the kit build for the first time and went through the pre-flight.  The wizard passed everything and filament loaded via autoload...one time.  Then autoload stopped working as I was heading to run the first layer calibration again.  The filament would unload, so the motor is working.  I turned off the  filament sensor and disabled autoloading.  The printer would load the filament with these settings in place.  For some reason I fired up the wizard again and the autoload worked...one time.   I tried to load again with it, but it just sits there, the feed gears do not turn unless I disable the filament sensor and autoload.  Odd that autoload works in the wizard and not from the menu.  Suggestions?  I didn't check the firmware.  I'll do that tomorrow.
Postato : 26/01/2022 10:37 pm
Titan
(@titan-2)
RE: MK3S+ kit autoloading fail
Potentially a filament sensor related issue due to the fs lever not triggering the sensor correctly. This may help: https://help.prusa3d.com/en/article/ir-filament-sensor-troubleshooting-mk2-5s-mk3s_112226
Postato : 27/01/2022 1:02 am
stellr
(@stellr)
Thanks for the pointer.  Lots of things to check there tomorrow.  Hopefully, one of them will fix it.  I'll be back.
Postato : 27/01/2022 1:55 am
stellr
(@stellr)
Connector was on the wrong row of pins.  It's hard for old eyes to see down in there.  I didn't even notice there were two rows. Works great now. Many thanks.
Postato : 31/01/2022 1:26 pm
Titan
(@titan-2)
Great stuff. Glad it was an easy fix.
Postato : 31/01/2022 4:15 pm
