MK3 - Extruder is not heating up after replacing Hot End Cartridge and Thermister
devang.p
(@devang-p)
Hello,
The cable for Extruder Hot End Heater was broken so I replace the Hot End Cartridge with 24V and 40W. I also replaced the Thermister. But now when I set the nozzle temp upto 200C, it is not heating up. Any suggestion on how to solve this issue?
Respondido : 15/11/2019 11:04 pm
rmm200
(@rmm200)
RE: MK3 - Extruder is not heating up after replacing Hot End Cartridge and Thermister
Did you replace the entire cable or splice the parts in?
I would check resistance of the heater line at the connector. Sure sounds like a bad connection / on wrong connector pins.
Respondido : 16/11/2019 12:34 am
Also - if while just sitting there the ambient nozzle temp reads 0 c, then the thermistor is not connected properly, or defective.
If you tighten the set screw that holds the cartridge in place too much, you can damage the thermistor, which is a glass bead inside a thin metal capsule.
Respondido : 16/11/2019 2:49 am
devang.p
(@devang-p)
Actually It was my fault. I didn't check the fuse. One of the fuses was blown out. I have replaced it and it working good now.
Thanks,
Respondido : 16/11/2019 2:19 pm
