Mesh bed fail
Knox Swafford
(@knox-swafford)
Mesh bed fail
 I'm new to 3d printing, And about a week ago I got a really big blob stuck to my purse mk3 i3. So I ordered a whole new extruder and every time I try to calibrate or do a print it shows the error code "bed leveling failed. Sensor didn't trigger. Debris on nozzel? Waiting for reset.
Veröffentlicht : 22/12/2021 3:50 pm
AndersK
(@andersk)
RE: Mesh bed fail
It might be a problem with the Pinda sensor. This is a guide how to test it.
https://help.prusa3d.com/en/article/p-i-n-d-a-superpinda-sensor-testing_2091
Veröffentlicht : 23/12/2021 5:43 am
AndersK
(@andersk)
RE: Mesh bed fail
Or the pinda just got pushed upwards
Did you do the pre-flight check after rebuilding?
https://help.prusa3d.com/en/guide/9-preflight-check_95128
Veröffentlicht : 23/12/2021 6:25 am
Robin
(@robin)
Knowledge base first, forum second
@knox-swafford I'd recommend to check the knowledge base before posting a request on the forum since the first thing you will be asked is what you did to solve your problem.
There is an entry for your exact problem, check it out here: https://help.prusa3d.com/en/article/bed-leveling-failed_2151
Veröffentlicht : 23/12/2021 4:23 pm
