Loud continuous beep upon first startup
Matthios Mengis
(@matthios-mengis)
Miembro
I just finished assembling the Prusa I3 Mk3s+, and on startup, there's a continuous beep for 3 or so seconds, and a break before it starts again indefinitely. The LCD also will not turn on (no brightness from it at all)
Respondido : 09/06/2023 8:44 pm
williamgray
(@williamgray)
Miembro
Posted by: @matthios-mengis
I just finished assembling the Prusa I3 Mk3s+, and on startup, there's a continuous beep for 3 or so seconds, and a break before rooftop snipers starts again indefinitely. The LCD also will not turn on (no brightness from it at all)
The continuous beep on startup of your Prusa I3 Mk3s+ could be due to a few reasons. One reason could be that the printer is detecting a problem with the temperature sensor. This could be due to a loose connection or a faulty sensor. Another reason could be that the firmware on the printer needs to be updated. You can try updating the firmware to see if that resolves the issue.
Esta publicación ha sido modificada el hace 3 years por williamgray
Respondido : 11/07/2023 9:08 am
