Loud continuous beep upon first startup
Matthios Mengis
(@matthios-mengis)
Mitglied
I just finished assembling the Prusa I3 Mk3s+, and on startup, there's a continuous beep for 3 or so seconds, and a break before it starts again indefinitely. The LCD also will not turn on (no brightness from it at all)
Veröffentlicht : 09/06/2023 8:44 pm
williamgray
(@williamgray)
Mitglied
Posted by: @matthios-mengis
I just finished assembling the Prusa I3 Mk3s+, and on startup, there's a continuous beep for 3 or so seconds, and a break before rooftop snipers starts again indefinitely. The LCD also will not turn on (no brightness from it at all)
The continuous beep on startup of your Prusa I3 Mk3s+ could be due to a few reasons. One reason could be that the printer is detecting a problem with the temperature sensor. This could be due to a loose connection or a faulty sensor. Another reason could be that the firmware on the printer needs to be updated. You can try updating the firmware to see if that resolves the issue.
Diese r Beitrag wurde geändert Vor 3 years von williamgray
Veröffentlicht : 11/07/2023 9:08 am
