Layer shift in same place
malthe.o
(@malthe-o)
I tried to print the model twice. The layer shift occur in the same exact place. The model is printed in the position as shown in the picture.
I have previously printed other models without layer shifts. The only difference this time is changing the layer height from 0,2 to 0,1mm. My belt stats are X:286 and Y:287. I know they are a bit high, but I've printed successfully with these belt tension numbers for some time.
Any suggestions? The fact that the layer change is the same place made me think its the STL. But I've printed the STL successfully before.
Other print info:
I'm on firmware 3.4.
Printing in silent mode.
Sliced with S3D
Printing from SD
Publié : 19/09/2018 7:58 pm
Kai
 Kai
(@kai-2)
Re: Layer shift in same place
It looks like you updated to R3.
Did you check your build twice.
I think about the nylon straps etc. that might hit the Frame or something else.
nec aspera terrent
Publié : 19/09/2018 10:01 pm
