Layer shift??
ricardo.sousa
(@ricardo-sousa)
Layer shift??
For objects such as trays, vases or pots, in the transition from the bottom to the wall, this always happens. I have no layer shift in the rest of the piece.Does anyone know why?
This topic was modified 7 years ago by ricardo.sousa
Posted : 22/05/2019 5:11 pm
vintagepc
(@vintagepc)
RE: Layer shift??
Does that perchance line up with the top solid infill inside the pot? If so that's a known issue that a number of other threads here have been investigating. I don't think anyone's pinned down the exact cause yet though, but I've heard reports that other slicers do not cause it.
Posted : 22/05/2019 6:18 pm
ricardo.sousa
(@ricardo-sousa)
RE: Layer shift??
Yes, that's it. In fact I have only used Slic3r, I will try to see if with others it happens.
Posted : 22/05/2019 7:10 pm
vintagepc
(@vintagepc)
RE: Layer shift??
Posted by: ricardo.sousa
I seem to recall someone reporting that setting a negative percentage for the infill overlap (-15%, I think?) fixed it for them. But it does also seem to be highly dependent on part geometry.
Posted : 22/05/2019 7:21 pm
ricardo.sousa
(@ricardo-sousa)
RE: Layer shift??
Posted by: vintagepc
I'm convinced that geometry matters. There are situations where it is less visible. Anyway thanks, it is already a help to see if I solve.
Posted : 22/05/2019 7:42 pm
