Layer Pickup / Down Issues
emperorcow
(@emperorcow)
I've been having an issue with my new i3 and need some advice. I'm having an issue where my layers (usually the first but not always) gets messy on Z axis pickups. I've attached a picture of a print stopped after the first layer.
I've tried various settings such as retraction length, various bed and extruder temperatures to no avail. Somewhat frustratingly, I know I'm the problem as if I use one of the gcode files provided direct from Prusa I get great results (attached a picture as well), but if I take an STL and go through Slic3r I have the issue. Thoughts on what else I can change to smooth out the layers? Otherwise the print head ends up dragging through everything and pulling the first layer off the bed.
Opublikowany : 22/10/2018 7:25 pm
LT7406
(@lt7406)
Re: Layer Pickup / Down Issues
I'm having similar issues. I can print the original files no problem but when I run something through PrusaControl,Silcer,or Octoprint its a crap shoot at best.. I think I got 2 things to print decent after multiple trys.
Opublikowany : 23/10/2018 2:22 pm
