Issue with vertical lines and ghosting
John Ryan
(@john-ryan)
Hi All,
I've had my MK3S for a few months now and have been really enjoying it. Lately I've been trying to figure out some issues with vertical lines on the Y axis and some ghosting in general. I added some felt pads under the feet and tried tweaking the belt tension (currently ~255 on X and Y). I was wondering if anyone had suggestions for what to try to help improve the prints (or if this is expected and I should stop messing around with stuff).
I've attached some photos - near the top of the print i dialed the speed down to 50% which seemed to help which makes me assume it's vibration / resonance related but any suggestions would be greatly appreciated!
Napsal : 29/05/2021 5:18 pm
Dan Rogers
(@dan-rogers)
RE: Issue with vertical lines and ghosting
Get some Prusament PETG and download the Belt Tension gauge GCODE for your printer (in print library)   the display units are more a measure of drag than then are belt tension.  And do check the grub-screw tightness on the X and Y axii
Napsal : 01/06/2021 12:26 am
