[Solved] Initial setup calibration problem print fan
holblin
(@holblin)
I just finished to build my prusa but when I start the initial checkup and calibration process, I had an error with the print fan (second fan). It runs but it seems that the prusa doesn't detect that.
I checked the cable and checks that this cable was not or is not pinched but that was not the case.
Did you have some idea?
Best Answer by RH_Dreambox:
If you read what is on the screen you will see that you must answer a question.
Answer the question with Yes or No, then your problem is solved 😉
Napsal : 26/05/2019 9:06 am
RH_Dreambox
(@rh_dreambox)
RE: Initial setup calibration problem print fan
Napsal : 26/05/2019 12:11 pm
holblin
(@holblin)
Yes, indead it solve the issue 🙂
I figure out with the support that the problem was between the keyboard and the chair!
I was thinking the question about the fan is spining or not is asked for the stopped one (the hotend fan) and then the spinning one (the print fan). And probably the french translation might be not perfectly accurate.
I also found some guy on the french forum which sound to also had issue to understand it correctly. Maybe change the question to [1] could help stupid answer like mine or better translation 😉
[1]
- Does only ONE fan is spinning? Y / N
-Which oneisspinning? left/front
Napsal : 27/05/2019 6:12 pm
