I got the first print layer blues
3DLibrarian
(@3dlibrarian)
So, I've been trying to print all day on my Prusa issue textured print bed but nothing is stopping that first layer from separating from the print bed and turning into a big gummy mess. I've tried isopropyl alcohol, I've tried washing it with dish soap and a sponge, I've calibrated, and I've even adjusted the Z-Axis so the nozzle isn't right on the plate. If anyone has any other ideas I would very much like to know them.
Opublikowany : 04/01/2021 6:31 pm
Cynan
(@cynan)
RE: I got the first print layer blues
Can we get a video or some photos? Thanks.
Opublikowany : 04/01/2021 8:53 pm
3DLibrarian
(@3dlibrarian)
So here is what I try to print, and here is what it ends up looking like. I even tried to put glue on the build plate but it just all turns into goop.
Opublikowany : 04/01/2021 9:24 pm
Cynan
(@cynan)
I notice that there is no part cooling duct in your photos.
What material are you printing with? I had very little success printing PLA with the textured print sheet, however PETG works fine. I did have to really scrub the sheet with warm water and dish soap though, perhaps give it another rinse? The live Z also took me a while to get dialed in, and even though the calibration on the printer looked good, when printing a large parts elsewhere on the bed it wasn't and I had to go lower. Also enable 7x7 mesh bed levelling if you have not done so already.
Opublikowany : 05/01/2021 9:51 am
RH_Dreambox
(@rh_dreambox)
The spaghetti around the nozzle is quite typical as the Z level is not properly calibrated.
The filament string is then not smeared on the bed but instead rolls up behind the nozzle.
Opublikowany : 05/01/2021 12:22 pm
3DLibrarian
(@3dlibrarian)
Attempted calibration of the Z axis this morning...goop on nozzle. Got rid of goop, then tried calibration of Z again. The calibration went through fine, but still nothing is sticking. Even with the glue. Even with multiple cleanings. I can only speculate that the pad is too old.
They shoot printer pads, don't they?
IRTI - funny GIF #2390 - tags: monty python joke card john cleese Flying  Circus
Opublikowany : 06/01/2021 4:28 pm
As @cynan notes, there is a LOT of variability with the textured beds, particularly with PLA. I gave up on my textured bed completely, while others reserve it for PETG and other sticky materials. I'd suggest going with a smooth PEI sheet, or one of the clone textured sheets for printing PLA.
Opublikowany : 06/01/2021 5:43 pm
