Hotend causes crash/newbuild
So i had some issues getting the printer up and running, worked wonderfully yesterday. Today I had a filament clog, tried to fix it, but now when I try to print it crashes right away and back to main menu, it's the hottend, not the bed. Tried adjusting temp for both, only crashes on the hottend. Didn't do anything to it other than trying to get the clog out which i didn't of course. What is wrong, its driving my mad...
RE: Hotend causes crash/newbuild
Also can't unload or autoload filament, its all dead?
It depends somewhat on what type of clog you had - but if the filament remained in the hotend for too long it may have baked hard - so a cold-pull would be the first remedy to try.
https://help.prusa3d.com/article/cold-pull-mk3s-mk2-5s_2075
Can't increase nozzle temperature, it crashes. Can't load filament either the motor seems dead...
Log into your Eshop account, navigate to Company, click Contact Us and 24/7 live Chat is one of the options. This is the quickest route to Prusa support.
Mare sure the hotend wires aren't touching. The ones with the red casing go bare just before the go into the metal block that the nozzle screws into.
No hotene wires are touching, if they do I get thermal error on the screen...this is impossible to figure out
Can you video this please not sure what you mean by crashes
