Grease Recommendation
Bilgic
(@bilgic)
Utenti
Hello,
Newbie here. I could not find the recommended grease brands here in Turkey with a reasonable price.
I can find SKF LGMT 3. Lithium Grease for bearings.
What do you think about it?
Thanks.
Questa discussione è stata modificata 5 years fa da Bilgic
-evren
Postato : 19/03/2021 11:59 am
Clarmrrsn
(@clarmrrsn)
RE: Grease Recommendation
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/trying-to-find-an-alternative-to-prusa-lubricant/#post-385240
Check this thread
There are also recommendations in the regular maintenance doc
https://help.prusa3d.com/en/article/i3-printers-regular-maintenance_2072
Tank you very much!
Postato : 20/03/2021 12:31 am
Clarmrrsn
(@clarmrrsn)
Lithium grease will be fine if you can't find anything else, just make sure the bearings are packed correctly, that is more important.
Tank you very much!
Postato : 20/03/2021 12:43 am
1 persone hanno apprezzato
