Gaps in on left side
terence.t2
(@terence-t2)
I set up the i3 mk3 kit over the weekends. Today, I printed the calibration sheet posted in https://shop.prusa3d.com/forum/assembly-and-first-prints-troubleshooting-f62/life-adjust-z-my-way-t2981.html . I started with z adjustment of -0.400 and -0.430 and they printed fine. I printed a couple more with -0.415, -0.450 and they all printed with any issues. But, when I got to -0.470, I saw the printed sheet has some scratches. After printing -0.470, I tried again with -0.430, -0.415, even -0.400 and they are now showing gaps on the far left side. You can see these gaps in the attached image. I cleaned the nozzle, re-did the calibration wizard and xyz calibration, but they didn't help. What else should I be checking?
Opublikowany : 18/01/2019 1:17 pm
Re: Gaps in on left side
as part of the XYZ calibration you normally drive the X axis to the top so that it rattles against the Z axis endstops, in order to level the X axis.
so that should be ok.
have you tried Bed Level correction, in the calibration menu?
Joan
Opublikowany : 18/01/2019 2:35 pm
terence.t2
(@terence-t2)
Joan
Thanks. Bed Level correction just left side didn't help. So, I tried adjusting both left and back and now printing better than before. I will need to play with the settings. Thanks again for the suggestion.
Opublikowany : 18/01/2019 8:08 pm
