Front Panel Button Problem
flatdog
(@flatdog)
I have assembled my printer and for the last couple of days have been happily making some great models.  This morning I started having problems with the button under the front panel potentiometer.  I it quite 'unreliable' and I have to press it several times to make it respond.  Until this morning it has been absolutely fine.  Any ideas on how to solve this?
Thank you,
Philip
Veröffentlicht : 21/10/2019 10:40 am
rmm200
(@rmm200)
RE: Front Panel Button Problem
The button with the big X on it is the Emergency Abort button. I never use it unless a print is going horribly wrong.
That said - chat with Support. Click on EShop above, log in to the store, then the Chat button is in lower right.
They can step you through it.
Veröffentlicht : 21/10/2019 4:49 pm
flatdog
(@flatdog)
I am talking about the button that activates a menu selection once it has been selected with the rotary 'dial'.  The rotary bit is working fine but the but pressing it does nothing.
Veröffentlicht : 21/10/2019 4:55 pm
The X is simple reset - I'm not even sure it does anything unless you are mid print.
Veröffentlicht : 21/10/2019 5:58 pm
flatdog
(@flatdog)
Sorry - I did not make myself clear.  I am not talking about the abort button.  I am referring to the button that is pressed to activate a menu selection - ie rotate the dial and press to activate the selected menu item.
Veröffentlicht : 21/10/2019 6:01 pm
Dave Avery
(@dave-avery)
the X button is the same as power cycling the printer
Veröffentlicht : 21/10/2019 8:43 pm
Posted by: @david-a66
That might be the intended function but my experience is different: it is not quite like a power cycle or hard reset.
Veröffentlicht : 22/10/2019 6:36 am
rmm200
(@rmm200)
OK - we are all talking about the wrong button. OP meant the one that is part of the rotary knob.
Contact Support. They may want to replace your display board.
Veröffentlicht : 22/10/2019 3:42 pm
