Front Panel Button Problem
I have assembled my printer and for the last couple of days have been happily making some great models. This morning I started having problems with the button under the front panel potentiometer. I it quite 'unreliable' and I have to press it several times to make it respond. Until this morning it has been absolutely fine. Any ideas on how to solve this?
Thank you,
Philip
RE: Front Panel Button Problem
The button with the big X on it is the Emergency Abort button. I never use it unless a print is going horribly wrong.
That said - chat with Support. Click on EShop above, log in to the store, then the Chat button is in lower right.
They can step you through it.
I am talking about the button that activates a menu selection once it has been selected with the rotary 'dial'. The rotary bit is working fine but the but pressing it does nothing.
The X is simple reset - I'm not even sure it does anything unless you are mid print.
Sorry - I did not make myself clear. I am not talking about the abort button. I am referring to the button that is pressed to activate a menu selection - ie rotate the dial and press to activate the selected menu item.
the X button is the same as power cycling the printer
That might be the intended function but my experience is different: it is not quite like a power cycle or hard reset.
OK - we are all talking about the wrong button. OP meant the one that is part of the rotary knob.
Contact Support. They may want to replace your display board.
