Topic starter
answered:
RE: Fresh Build - X Axis issue
Fixed my own issue after a bit of researching. Problem was x axis belt was too tight. x and y belts are around 250 now and xyz cube is spot on perfect.
Opublikowany : 31/01/2021 11:44 pm
@itkosta29
It's worth downloading the belt tightening gauge pattern from the library - it's a GCODE file that prints out a physical gauge that you slip onto the belt (per directions provided with the pattern) and lets you see the upper/lower range. Good backup for the numbers on the screen.
Opublikowany : 02/02/2021 6:21 pm
Topic starter
answered:
@dan-rogers
Cool thanks. Could you please link me to the page you are suggesting?
Opublikowany : 02/02/2021 6:40 pm
