First time printer -- trying to use NinjaFlex
Chad Stewart
(@chad-stewart)
Hi -- I just built my prusa yesterday and ran through the calibrations to get everything working.
I was trying to change the filament to use a flexible material (NinjaFlex) to print some things. The filament seems to get jammed going into the extruder and nothing come out. See pic. The pic is hard to see exactly -- but what appears to be happening is that the filament is being pulled in and bends slightly (because it's flexible) and bends under the pulley, then gets caught and the filament no longer comes out of the nozzle. I've tried changing temps between what NinjaFlex recommends 210-225/20-30 and the preprogrammed flexible temps 240/50. But it's getting caught each time. Any ideas on how to fix this?
Best Answer by JoanTabb:
try reducing the bondtech idler gear pressure to the absolute minimum, try the semiflex or flexfill 98a filament profile, and disable retraction (set value to 0),
Veröffentlicht : 04/08/2019 4:52 pm
Chad Stewart
(@chad-stewart)
RE: First time printer -- trying to use NinjaFlex
Tried to remove this by unloading and somehow the filament got twisted around the pulley but going the wrong way -- I have no idea how to get it out.
Veröffentlicht : 04/08/2019 5:44 pm
Chad Stewart
(@chad-stewart)
Got the filament. But root problem (filament getting jammed/bent/not printing correctly) remains the same. PLA is just fine
Veröffentlicht : 04/08/2019 5:56 pm
Veröffentlicht : 04/08/2019 9:32 pm
Chad Stewart gefällt das
Chad Stewart
(@chad-stewart)
Thanks @joantabb -- that definitely helped but I don't think it completely fixed it.
Filament: NinjaFlex
Settings:
- Printer: Default + 0 retractor, bondtech gear pressure @ min
- Filament: Semiflex or Flexfill 98a
I was able to print a simple extruder motor visualizer, but my second print after failed & the filament got really twisted:
Here's a pick of the print before I interrupted it
Veröffentlicht : 05/08/2019 4:27 am
Chad Stewart
(@chad-stewart)
This is what I was going for:
Attachment removed
Veröffentlicht : 05/08/2019 4:28 am
Chad Stewart
(@chad-stewart)
I'm thinking the bondtech gear is too far from the extruder barrel and/or the filament is not running in smooth enough so it's bending? I'm not sure how to adjust it to make it closer though
Veröffentlicht : 05/08/2019 4:37 am
Dave Avery
(@dave-avery)
also try printing slower - flex filaments need very slow speeds
Veröffentlicht : 05/08/2019 4:38 am
Chad Stewart
(@chad-stewart)
Yeah was just reading some stuff on NinjaFlex that said do everything at 50-80% speed. I've clocked all that down & am going to try again.
I've become very adept at removing the flexible filament when it gets tangled though. Lol
Veröffentlicht : 05/08/2019 4:43 am
Chad Stewart
(@chad-stewart)
Just attempted again with slower speed -- same thing happened. I'm thinking it's that spacing in there. I'm just noticing my extruder motor might be slightly rotated causing the space between the extruder barrel and the bondtech pulley. Faults of building it yourself I guess
Is this gonna be hard to adjust? 😡
Veröffentlicht : 05/08/2019 4:54 am
Chad Stewart
(@chad-stewart)
Ahhhhhh the nut on the extruder door wasn't all the way in -- so it was causing extra pressure on the firmament because the screw had to reach further. After getting that better in there, the pressure on the filament was low enough to not cause the tangling. Thanks for the help everyone!
Veröffentlicht : 05/08/2019 5:40 am
Bruce
(@bruce)
@chadws
What is your final slice setting? Would you please take a screenshot out of it? Everything happened to you has exactly been happening to me.
Veröffentlicht : 07/10/2019 7:22 am
