First prints (need calibration help!)
cemo
 cemo
(@cemo)
Does anyone know what some of these artifacts are caused by? Any suggestions on where to start with my troubleshooting? I've tried the basic tips in the first layer issue guide without much success.
Postato : 14/01/2020 3:30 pm
MasterHead
(@masterhead)
RE: First prints (need calibration help!)
From the photos seems clear that you need to adjust the first layer calibration but i'm no expert.
Which is your z value? Have you followed the "life adjust Z - My way" post? ( https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/life-adjust-z-my-way/ )
I think you need to take closer the nozzle to the bed, it seems too far away. Maybe be try with -100 increments until it seems squeezed but solid, with no transparency
if you are, for example, at -1000 move it live to -1100 and then to -1200 and so on, so you can see how it afects the print square from the post.
From the post Live adjust the image " " shows examples, whith the following explanation:
"when the life adjust value is too high, the surface gets a little bit rough and dim. you can feel it very good when you fondle over it with your fingers.
at the edge with the -650 & -600 µm, you can even see some little crumbles, small blisters and very fine strings. i stopped here at -650 µm because i won't risk to damage my PEI sheet."
 -575 semms pretty good to me, in your photo it seems to need to squeeze the filament.
Postato : 14/01/2020 4:15 pm
cemo
 cemo
(@cemo)
@masterhead
I think that's definitely part of it. But I think there's something else going on too.
Here's what it looked like when I printed the file attached to the live Z adjustment post that you shared. Z height definitely needs to be adjusted, but there's something else going wrong too.
It also looks like my PINDA probe is slightly off center of the target. I wonder if it's off enough to cause issues with printing.
Postato : 14/01/2020 6:42 pm
rmm200
(@rmm200)
PINDA height matters. X - Y location - not so much.
Prusa sets home based on the PINDA location - not what the heat bed shows. What you picture is fine.
And don't just print out your calibration square and look at it.
Actively change Z while it is printing until you get a nice solid surface. That value will be saved by the firmware for the sheet you specified.
Postato : 15/01/2020 1:04 am
MasterHead
(@masterhead)
As Robert-rmm200 said i think you should live adjust the Z and once its in place review next steps.
Postato : 15/01/2020 8:19 am
MasterHead
(@masterhead)
Also, if not already, it might be a good idea to use the "7x7 mesh bed leveling" option in order to improve the variations of the bed, it takes a bit longer to start printing but it's worth the shot
Postato : 15/01/2020 8:51 am
