First Print Help
NurseJORJ
(@nursejorj)
First Print Help
I'm on my first print after (what I thought was successful) Z-Axis calibration. I'm assuming by what I'm already seeing, the extruder height may be too low?
Veröffentlicht : 02/11/2022 4:49 pm
To judge the first layer Z we ask for a clear picture of the first layer Z calibration print *on the print sheet*.  The bottom of a failed print often helps as well.
I can't really judge from that picture as there's some motion blur but I can see some fingerprints on the sheet that would affect adhesion.  Look up threads about cleaning the print sheet and if the problem persists come back with a new picture.
Veröffentlicht : 02/11/2022 8:39 pm
Costello102
(@costello102)
RE: First Print Help
It looks like the issue I was having setting up my MK3 yesterday. The filament wouldn't stick to the sheet because the Z height was to high. I kept running the first layer calibration and the Prusa test print and ran the Z height down to -1.750. The directions scare you not to go too low, but it took quite a bit to get it right.  Read how to do the real time Z height adjustment and run the Prusa test print.
Veröffentlicht : 03/11/2022 6:50 pm
