First Print Benchy Issue
Necdet Şanlı
(@necdet-sanli)
Mitglied
Hi, I bought a used mk3s+ and assembled it according to the guide. Everything seems fine but my benchy has problems. Here are the pictures:
What is the problem? Thank you.
Veröffentlicht : 28/01/2026 5:52 pm
It's always risky buying second hand kit - you never know how it's been treated.
A couple of general comments:  So many Benchy remixes and variants have appeared in recent years that an unspecified Benchy is no longer a good diagnostic tool - download the original file from:  https://www.3dbenchy.com/    - this is the file to use for diagnostics.
But I wouldn't bother printing a Benchy unless there was some subtle issue to diagnose, your problem isn't subtle.
- and - white and pastel filaments are the trickiest to print as they contain so much pigment that the melt doesn't behave like other colours, it often becomes non-Newtonian. Grey is often the best colour for problem chasing.
The two most likely causes of your issues are:  If you have (re)built from scratch you may have misaligned the grub screws on the X and/or Y drive pulleys.
Or:
Your belt tension is wrong.
Tighten the belt until it just begins to make a low musical note when plucked...  while you're at it put a tiny dab of silicone grease on your smooth rods, not the lead-screws.
If the printer works, make your next print this:
https://www.prusaprinters.org/prints/46639-tension-meter-for-the-gt2-belts-of-i3-mk3s-or-prus
It MUST be printed in Prusament PETG or the spring tension will be wrong.
I suspect you have another issue masked by the  rippled extrusions but let's clean them up first.
Let us know how you get on.
Veröffentlicht : 29/01/2026 5:48 am
