First print after assembly, layer shift
I assembled my MK3S+ and printed the benchy that was on the SD card in PLA.
I tried both Argos PLA and Pursament PLA, same results.
Any ideas what would cause this?
Best Answer by Neophyl:
Check your motor pulley grub screws are correctly installed on the flat of the shafts and have been tightened in the correct order.
Opublikowany : 14/03/2023 8:26 pm
RE: First print after assembly, layer shift
Opublikowany : 15/03/2023 6:04 am
