First print after assembly, layer shift
Martian35g
(@martian35g)
I assembled my MK3S+ and printed the benchy that was on the SD card in PLA.
I tried both Argos PLA and Pursament PLA, same results.
Any ideas what would cause this?
Best Answer by Neophyl:
Check your motor pulley grub screws are correctly installed on the flat of the shafts and have been tightened in the correct order.
Posted : 14/03/2023 8:26 pm
Martian35g
(@martian35g)
I printed the tension test, belt tension looks good
Posted : 14/03/2023 9:08 pm
RE: First print after assembly, layer shift
Posted : 15/03/2023 6:04 am
Martian35g
(@martian35g)
I originally looked at them and they looked good. But after you mentioned it I went ahead and reseated them. That worked, thanks! I got a good benchy.
Posted : 16/03/2023 9:37 am
Neophyl liked
